MMC "debug" mode AND HELPFUL MMC BUG FIXES ; TV START UP PROBLEMS
Hi, thanks to this thread I am close to solving this issue (conexc.dll).
My tv-live.txt log file says (at the end):
[06:28:44] Found Filter: DV Audio -- PAL
[06:28:44] Loading Filter: WMAudio Encoder DMO
[06:28:44] Loading Filter: WM Speech Encoder DMO
[06:28:45] Loading Filter: Indeo® audio software
[06:28:45] Loading Filter: Nero Audio Encoder
I assume that it is the Nero Audio Encoder based on earlier postings. I cannot find the dang thing. I have textt searched the c: drive for NERO. I have searched for Nero in the registry and found no NERO AUDIO ENCODER. I have used RegCleaner for OLE and orphan files. Nothing. Drive Cleaner has nothing for Nero.
Can someone help me out here?? Thanks,
Lar
ATIMMC COMEXE.DLL ERROR
I think I have a similar issue. I am trying to start TV 7.1 from ATI Media Center 7.1. I get a ATIMMC error referencing COMEXE.DLL. I am running a Rage 128 card and All In Wonder 128 PCI software on a old computer with a Pentium MMX chip. I have DirectX8.a software, having replaced the 9.0. The 9.0 DXDIAG indicated my AGP Texture Acceleration was not available. With 8.a DXDIAG does not run at all. I dont understand all that is going on in this discussion, nor do I know if it applies to me. But if it does, I would appreciate someone walking me through a fix.
MMC 8.8 hangs on startup
If I reboot my computer, MMC 8.8 works fine. But if it sits idle long enough for
the screen to blank and harddrive to spin down, then MMC 8.8 will not start.
I have Cat 4.2 installed, DX9, and all the latest support files (DAO, etc.).
I did a clean install of all of these.
When I enable the debug bits in the registry, I see the following lines
in the TV-Live.txt file:
*** Log Manager 0: Opened on: 3/5/04 [12:10:01]
Connector Executor: [12:10:01] ENTER ::EnumFilterClass()
Connector Executor: [12:10:01] Found Filter: SB Live! Wave Device
Connector Executor: [12:10:01] Found Filter: SB Live! MIDI UART
Connector Executor: [12:10:01] Found Filter: ATI Rage Theater Video Capture
Connector Executor: [12:10:01] Found Filter: ATI Rage Theater Audio
Connector Executor: [12:10:01] EXIT ::EnumFilterClass() OK...
Connector Executor: [12:10:01] ENTER ::LoadEnumFilter()
Connector Executor: [12:10:01] Loading Filter: SB Live! Wave Device
Connector Executor: [12:10:01] EXIT ::LoadEnumFilter () *ppIFilter != NULL....
Connector Executor: [12:10:01] Loading Filter: SB Live! MIDI UART
The file ErrorLog.txt only has the following:
*** Log Manager 0: Opened on: 3/5/04 [07:32:48]
[07:32:49] COSIController::PaintCache failed to paint to screen
[07:32:50] COSIController:AttachFeature: no genUI interface, will load all OSIs
[07:32:50] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
I'm using a AIW Radeon, on a sis-735 based motherboard with a Duron 900MHz.
I also have a SBLive installed.
Previous versions of MMC worked better then this, only hanging once in a while.
I currently cannot install MMC 8.9 because of an install error.
Any ideas?
Thanks,
Paul
After formatting I installed the Cat 4.3 and MMC 8.9 stuff, only to find that I get this error too. I've tried cleaning my drivers to no avail... Device manager shows no problems. Here's my log:
*** Log Manager 0: Opened on: 3/15/2004 [03:51:28]
[03:51:29] COSIController:AttachFeature: no genUI interface, will load all OSIs
[03:51:29] COSIController::PaintCache failed to paint to screen
[03:51:29] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[03:51:29] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=16
[03:51:29] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[03:51:29] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[03:51:29] ResMngr::Command Line=/TV+ UIO Guid=
[03:51:29] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[03:51:29] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[03:51:29] TVUIO::PreStartUp - Optional ConO DV failed to load
[03:51:29] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[03:51:29] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[03:51:29] TVUIO::StartUp: Display ConO - Invoking Startup...
[03:51:29] Display::Could Not Localize RegPath for \Title
[03:51:29] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[03:51:29] CTvDisp::SetupDriverObject: failed to create the Analog TV Display Driver layer
[03:51:29] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[03:51:29] TVUIO::Startup Failed InitDisplay on Display
[03:51:43] [PowerManagement] CPowerEntry not found! Cannot Remove Entry
[03:51:43] [ResMngr] CResMngrApp::LoadApplications() FAIL to StartUp UIO
[03:51:43] ObjectTable::Leak Feature={A62213CA-80ED-11D0-AEDB-008029E646D0} Class={A62213CA-80ED-11D0-AEDB-008029E646D0} Instance=1
[03:51:43] ObjectTable::Leak Feature={6496DE69-CA7F-11CF-BD3C-008029E89281} Class={6496DE69-CA7F-11CF-BD3C-008029E89281} Instance=1
*** Log Manager 0: Closed on: 3/15/2004 [03:51:43]
Any help would be greatly appreciated :)
I decided to waste some time again this afternoon trying to get the TV Player to work in my default setup. I know that it CAN work on my system since I have it working in a second XP boot partition I configured with only MMC installed and none of my other apps. Other TV players using the ATI WDM drivers do work in the default partition where MMC fails.
I've previously tried all the manual and software-assisted uninstall/reinstall procedures decribed int his thread and others, with no effect. Here's my log which reports a problem loading the "WDM VBI Splitter", which, as far as I've been able to determine is a sub-componet of one of the ATI WDM drivers. Anyone see this before and/or have additional ideas (other than a complete re-install) to get past this problem?
[18:13:23] COSIController:AttachFeature: no genUI interface, will load all OSIs
[18:13:23] COSIController::PaintCache failed to paint to screen
[18:13:24] COSIController:AttachFeature: no genUI interface, will load all OSIs
[18:13:24] ResMngr::GetObject CoCreate Error: ClassNotReg CLSID: {CA0974B8-2353-41AC-9562-7FD6BA6B27A3}
[18:13:24] [MsgBox] Startup: Failed to CoCreateInstance for IID_IRemoteWonderInfo interface
[18:13:24] [TenFtUI] LoadApplet: Failed to startup applet {F80F96F3-F597-4BBE-9C39-A6F742A06057}
[18:13:24] ResMngr::Found Feature: Name=DVD Cmd=DVD GUID={5C4A58A0-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[18:13:24] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[18:13:24] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=16
[18:13:24] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[18:13:24] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[18:13:24] ResMngr::Command Line=/TV+ UIO Guid=
[18:13:24] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[18:13:24] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[18:13:24] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {C7856826-CA7F-11CF-BD3C-008029E89281}
[18:13:24] TVUIO::PreStartUp - Optional ConO DV failed to load
[18:13:24] TVUIO::PreStartUp - Optional ConO GallerySet failed to load
[18:13:24] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[18:13:25] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[18:13:25] TVUIO::StartUp: Display ConO - Invoking Startup...
[18:13:25] Display::Could Not Localize RegPath for \Title
[18:13:25] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[18:13:25] CDrvDisp:SelectDecoder: Name=ATI Rage Theater Video Capture Index=1
[18:13:25] CDrvDisp:Setup: Starting with 2 Crossbars for Audio & Video
[18:13:25] CDrvDisp:Setup: Preview Out is not available on Capture Filter
[18:13:25] CDrvDisp:Setup: Starting up using Format Converter as Capture Tee
[18:13:25] CDrvDisp:SetDefDispMode: Selecting Video Capture Display Mode: 0
[18:13:25] CDrvDisp:SetBestCapture: Setting Capture Pin: 720x240 @59.94fps (165722112bps)
[18:13:25] CDrvDisp:SetVBIFormat: SetFormat: 1 on VBI pin
[18:13:25] CDrvDisp:SetVBIFormat: VBI pin NOT connected
[18:13:25] CDrvDisp:SetVBIFormat: MediaType on VBI Pin: Standard Succesfully set to: 1
[18:13:25] CDrvDisp:SetFmtConvert: AIW
[18:13:25] CDrvDisp:SetFmtConvert: Video Delay set to 200
[18:13:25] CDrvDisp:Setup_LiveStdPerf: Rendering Live Video via VideoPort
[18:13:25] CDrvDisp:VBISetup: Failed to Load WDM VBI Splitter
[18:13:25] CDrvDisp:VBISetup: VBI Setup Failed
[18:13:25] CTvDisp::SetupDriverObject: Failed to initialize Driver
[18:13:25] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[18:13:25] TVUIO::Startup Failed InitDisplay on Display
Long Standing Problem
Here's my log file. Something is obviously wrong. I'm current with all drivers. Any ideas???
*** Log Manager 0: Opened on: 4/9/2004 [01:18:29]
[01:18:29] COSIController:AttachFeature: no genUI interface, will load all OSIs
[01:18:29] COSIController:CreateBackSurface: Failed to Create DirectDraw surface error=1
[01:18:29] COSIController::PaintCache failed to paint to screen
[01:18:29] ResMngr::GetObject CoCreate Error: ClassNotReg CLSID: {CA0974B8-2353-41AC-9562-7FD6BA6B27A3}
[01:18:29] [MsgBox] Startup: Failed to CoCreateInstance for IID_IRemoteWonderInfo interface
[01:18:29] [TenFtUI] LoadApplet: Failed to startup applet {F80F96F3-F597-4BBE-9C39-A6F742A06057}
[01:18:29] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[01:18:29] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=16
[01:18:29] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[01:18:29] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[01:18:29] ResMngr::Command Line=/TV+ UIO Guid=
[01:18:29] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[01:18:30] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[01:18:30] TVUIO::PreStartUp - Optional ConO DV failed to load
[01:18:30] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[01:18:31] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[01:18:31] TVUIO::StartUp: Display ConO - Invoking Startup...
[01:18:31] Display::Could Not Localize RegPath for \Title
[01:18:31] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[01:18:32] CDrvDisp:SelectDecoder: Name=ATI Rage Theater Video Capture Index=1
[01:18:32] CDrvDisp:Setup: Starting with 2 Crossbars for Audio & Video
[01:18:32] CDrvDisp:Setup: Warning FAILED CoCreate on VP Surface Allocator
[01:18:32] CDrvDisp:Setup: Preview Out is not available on Capture Filter
[01:18:32] CDrvDisp:Setup: Starting up using Format Converter as Capture Tee
[01:18:32] CDrvDisp:SetDefDispMode: Selecting Video Capture Display Mode: 0
[01:18:32] CDrvDisp:SetBestCapture: Setting Capture Pin: 720x240 @59.94fps (165722112bps)
[01:18:32] CDrvDisp:SetVBIFormat: SetFormat: 1 on VBI pin
[01:18:32] CDrvDisp:SetVBIFormat: VBI pin NOT connected
[01:18:32] CDrvDisp:SetVBIFormat: MediaType on VBI Pin: Standard Succesfully set to: 1
[01:18:32] CDrvDisp:SetFmtConvert: AIW
[01:18:32] CDrvDisp:SetFmtConvert: Video Delay set to 200
[01:18:32] CDrvDisp:CreatePlayBackGraph: VP Surface Allocator is not Present for TimeShifting
[01:18:32] CDrvDisp::UseAlternateOverlayMixer: Attempting to Use OverlayMixer1
[01:18:32] CDrvDisp::FinalSetup::Warning FAILED to enter Live (Std-Performance)
[01:18:32] CTvDisp::SetupDriverObject: Failed to initialize Driver
[01:18:32] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[01:18:32] TVUIO::Startup Failed InitDisplay on Display
Re: conexc.dll - FIX FOUND! + MMC "debug" mode
eddie said:
So I learnt one fun thing about MMC in the process, there is a way to get it to show you some debug info (sorry ATI if this was "hidden stuff")
Create the following:
[HKEY_LOCAL_MACHINE\SOFTWARE\ATI Technologies\Multimedia\ErrorLog]
"Min"="0"
"Max"="1000"
"Window"="500"
"File"="C:\\logme.txt"
I DONT KNOW if min, max, and window are appropriate values, but this will make MMC, upon startup, open debug/log windows you can look at for info...
Am I doing this debug wrong in my registry? Here's what I have (exported):
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\ATI Technologies\ErrorLog]
"Min"=dword:00000000
"Max"=dword:000003e8
"Window"=dword:000001f4
"File"="g:\\\\temp\\\\atilog.txt"
It didn't make any file. Thank you in advance.
Check your key, it must be:
"[HKEY_LOCAL_MACHINE\SOFTWARE\ATI Technologies\Multimedia\ErrorLog]"
Why so many backslashes in the filename? Your window entry is also wrong.
If you create exact the same key like described, then you will get an error loggin windows.
-Klaus-
-Klaus-
Ahhhhhhhhhhhh! OK, I will try again tonight. I hope I can figure out why my MMC's recorder doesn't record during scheduled times. Thanks. :)
Thanks that worked. Now, I just need to wait for the problem to come back. I think the recorder is teasing me. I can't reproduce it. LOL!
:D :D :D :D
Thank you, Thank you, Thank you.
I had MMC TV behaving 3 different ways for 3 different users. It turns out I had corrupted ring buffer files. I delete the old ones and lo' and behold it works just fine for all users now.
MMC 8.9
I get the "TV failed to initialize" error also, on my HP laptop when trying to launch my TV app and view the video via Easyshare.
The PC Check says that DirectX9 is not installed and that the capture driver is not installed. However I have installed DirectX9, Wimdows Media Encoder, and the WDM Capture drivers MANY times successfulyy.
So...here is my log file. What's going on? What does this mess mean?
*** Log Manager 0: Opened on: 6/7/2004 [22:10:43]
[22:10:43] COSIController:AttachFeature: no genUI interface, will load all OSIs
[22:10:44] COSIController::PaintCache failed to paint to screen
[22:10:44] COSIController:AttachFeature: no genUI interface, will load all OSIs
[22:10:44] ResMngr::GetObject CoCreate Error: ClassNotReg CLSID: {CA0974B8-2353-41AC-9562-7FD6BA6B27A3}
[22:10:44] [MsgBox] Startup: Failed to CoCreateInstance for IID_IRemoteWonderInfo interface
[22:10:45] [TenFtUI] LoadApplet: Failed to startup applet {F80F96F3-F597-4BBE-9C39-A6F742A06057}
[22:10:45] ResMngr::Found Feature: Name=EAZYSHARE TV Cmd=RTV GUID={3243FD0F-F982-48FA-8915-550572CFD6B5} #of Extensions= 0
[22:10:45] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[22:10:45] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=16
[22:10:45] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[22:10:45] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[22:10:45] ResMngr::Command Line=/TV+ UIO Guid=
[22:10:45] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[22:10:48] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[22:10:48] TVUIO::PreStartUp - Optional ConO DV failed to load
[22:10:48] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[22:10:56] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[22:10:56] TVUIO::StartUp: Display ConO - Invoking Startup...
[22:10:57] Display::Could Not Localize RegPath for \Title
[22:10:57] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[22:10:59] CDrvDisp:SelectDecoder: Name= Index=-1
[22:10:59] CTvDisp::SetupDriverObject: Failed to initialize Driver
[22:10:59] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[22:10:59] TVUIO::Startup Failed InitDisplay on Display
[22:11:42] [PowerManagement] CPowerEntry not found! Cannot Remove Entry
[22:11:43] [ResMngr] CResMngrApp::LoadApplications() FAIL to StartUp UIO
[22:11:43] ObjectTable::Leak Feature={6496DE69-CA7F-11CF-BD3C-008029E89281} Class={6496DE69-CA7F-11CF-BD3C-008029E89281} Instance=1
*** Log Manager 0: Closed on: 6/7/2004 [22:11:43]
This is doing my head in. I've reinstalled everything many times. x800 VIVO.
It worked once then stopped, then worked once then stopped.
[20:57:30] [TenFtUI] Startup: Succeeded to SetRendererMode OSI Controller
[20:57:30] ResMngr::GetObject CoCreate Error: ClassNotReg CLSID: {CA0974B8-2353-41AC-9562-7FD6BA6B27A3}
[20:57:30] [MsgBox] Startup: Failed to CoCreateInstance for IID_IRemoteWonderInfo interface
[20:57:30] [TenFtUI] LoadApplet: Failed to startup applet {F80F96F3-F597-4BBE-9C39-A6F742A06057}
[20:57:30] ResMngr::Found Feature: Name=Video In Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[20:57:30] ResMngr::Command Line=/TV+ UIO Guid=
[20:57:30] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[20:57:30] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[20:57:30] TVUIO::PreStartUp - Optional ConO DV failed to load
[20:57:30] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[20:57:30] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[20:57:30] TVUIO::StartUp: Display ConO - Invoking Startup...
[20:57:30] Display::Could Not Localize RegPath for \Title
[20:57:30] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[20:57:30] CDrvDisp::FilterVidDecoders Removing Non ATI (Decoder with VP)!
[20:57:30] CDrvDisp:SelectDecoder: Name= Index=-1
[20:57:30] CTvDisp::SetupDriverObject: Failed to initialize Driver
[20:57:30] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[20:57:30] TVUIO::Startup Failed InitDisplay on Display
Any idea's?
Need help understanding what is happening (error log)
I am unable to get the TV function to work with my asus 9600 VIVO, here is my error log.
I have tried the 4.8, 4.9 and 4.10 cats without success.
Tried SP1 and 2 for XP pro.
Tried disabling Fast Writes.
Capture works fine with PowerDirector pro.
Need help.
Thanks.
*** Log Manager 0: Opened on: 10/19/2004 [22:59:16]
[22:59:16] Schedule::Could Not Localize RegPath for \Schedule\Names
[22:59:16] Schedule::Could Not Localize RegPath for \Schedule\Descriptions
[22:59:16] COSIController:AttachFeature: no genUI interface, will load all OSIs
[22:59:17] COSIController::PaintCache failed to paint to screen
[22:59:17] COSIController:AttachFeature: no genUI interface, will load all OSIs
[22:59:17] ResMngr::GetObject CoCreate Error: ClassNotReg CLSID: {CA0974B8-2353-41AC-9562-7FD6BA6B27A3}
[22:59:17] [MsgBox] Startup: Failed to CoCreateInstance for IID_IRemoteWonderInfo interface
[22:59:17] [TenFtUI] LoadApplet: Failed to startup applet {F80F96F3-F597-4BBE-9C39-A6F742A06057}
[22:59:17] ResMngr::Found Feature: Name=EAZYSHARE TV Cmd=RTV GUID={3243FD0F-F982-48FA-8915-550572CFD6B5} #of Extensions= 0
[22:59:17] ResMngr::Found Feature: Name=DVD Cmd=DVD GUID={5C4A58A0-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[22:59:17] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[22:59:17] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[22:59:17] ResMngr::Command Line=/TV+ UIO Guid=
[22:59:17] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[22:59:17] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[22:59:17] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {DA043586-CA7F-11CF-BD3C-008029E89281}
[22:59:17] TVUIO::PreStartUp - Optional ConO DV failed to load
[22:59:17] TVUIO::PreStartUp - Optional ConO GallerySet failed to load
[22:59:17] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[22:59:17] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[22:59:17] TVUIO::StartUp: Display ConO - Invoking Startup...
[22:59:17] Display::Could Not Localize RegPath for \Title
[22:59:17] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[22:59:17] CDrvDisp::FilterVidDecoders Removing Non ATI (Decoder with VP)!
[22:59:17] CDrvDisp:SelectDecoder: Name= Index=-1
[22:59:17] CTvDisp::SetupDriverObject: Failed to initialize Driver
[22:59:17] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[22:59:17] TVUIO::Startup Failed InitDisplay on Display
[23:01:13] [PowerManagement] CPowerEntry not found! Cannot Remove Entry
[23:01:13] [ResMngr] CResMngrApp::LoadApplications() FAIL to StartUp UIO
[23:01:13] ObjectTable::Leak Feature={6496DE69-CA7F-11CF-BD3C-008029E89281} Class={6496DE69-CA7F-11CF-BD3C-008029E89281} Instance=1
*** Log Manager 0: Closed on: 10/19/2004 [23:01:13]
Hmzzzz, I am the KING of F****ed up logs:
Tel me what you think.....It seems worse case scenario to me:
[20:26:58] CDispRender:SetRendererMode: Failed to Set to NoOverlay_Mode
[20:26:58] [TenFtUI] Startup: Failed to SetRendererMode OSI Controller
[20:26:59] CDispRender:CreateBackVidSurface: Failed to Create DirectDraw surface error=1
[20:26:59] CDispRender:SetRendererMode: Failed to Set to NoOverlay_Mode
[20:26:59] [TenFtUI] Startup: Failed to SetRendererMode OSI Controller
[20:27:00] CDispRender:CreateBackVidSurface: Failed to Create DirectDraw surface error=1
[20:27:00] CDispRender:SetRendererMode: Failed to Set to NoOverlay_Mode
[20:27:00] [TenFtUI] Startup: Failed to SetRendererMode OSI Controller
[20:27:01] CDispRender:SetRendererMode: Failed to Set to NoOverlay_Mode
[20:27:01] [TenFtUI] Startup: Failed to SetRendererMode OSI Controller
[20:27:01] CDispRender:CreateBackVidSurface: Failed to Create DirectDraw surface error=1
[20:27:02] CDispRender:CreateBackVidSurface: Failed to Create DirectDraw surface error=1
[20:27:02] CDispRender:SetRendererMode: Failed to Set to NoOverlay_Mode
[20:27:02] [TenFtUI] Startup: Failed to SetRendererMode OSI Controller
[20:27:03] ResMngr::Failed to Startup TenFtUI Object
[20:27:04] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[20:27:04] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=16
[20:27:04] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[20:27:04] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[20:27:04] ResMngr::Command Line=/TV+ UIO Guid=
[20:27:04] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[20:27:05] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[20:27:05] TVUIO::PreStartUp - Optional ConO DV failed to load
[20:27:05] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[20:27:09] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[20:27:09] TVUIO::StartUp: Display ConO - Invoking Startup...
[20:27:10] Display::Could Not Localize RegPath for \Title
[20:27:10] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[20:27:11] CDrvDisp:SelectDecoder: Name=ATI Rage Theater Video Capture Index=1
[20:27:12] CDrvDisp:Setup: Starting with 2 Crossbars for Audio & Video
[20:27:13] CDrvDisp:Setup: Warning FAILED CoCreate on VP Surface Allocator
[20:27:13] CDrvDisp:Setup: Preview Out is not available on Capture Filter
[20:27:13] CDrvDisp:Setup: Starting up using Format Converter as Capture Tee
[20:27:13] CDrvDisp:SetDefDispMode: Selecting Video Capture Display Mode: 0
[20:27:13] CDrvDisp:SetBestCapture: Setting Capture Pin: 720x240 @59.94fps (165722112bps)
[20:27:13] CDrvDisp:SetVBIFormat: SetFormat: 1 on VBI pin
[20:27:13] CDrvDisp:SetVBIFormat: VBI pin NOT connected
[20:27:13] CDrvDisp:SetVBIFormat: MediaType on VBI Pin: Standard Succesfully set to: 1
[20:27:13] CDrvDisp:SetFmtConvert: AIW
[20:27:13] CDrvDisp:SetFmtConvert: Video Delay set to 200
[20:27:13] CDrvDisp:CreatePlayBackGraph: VP Surface Allocator is not Present for TimeShifting
[20:27:13] CDrvDisp::UseAlternateOverlayMixer: Attempting to Use OverlayMixer1
[20:27:13] CDrvDisp::FinalSetup::Warning FAILED to enter Live (Std-Performance)
[20:27:14] CTvDisp::SetupDriverObject: Failed to initialize Driver
[20:27:14] CTvDisp::SetupDriverObject:FAILED to SetupDriverObject
[20:27:14] TVUIO::Startup Failed InitDisplay on Display
[20:27:17] [PowerManagement] CPowerEntry not found! Cannot Remove Entry
[20:27:18] [ResMngr] CResMngrApp::LoadApplications() FAIL to StartUp UIO
[20:27:18] ObjectTable::Leak Feature={6496DE69-CA7F-11CF-BD3C-008029E89281} Class={6496DE69-CA7F-11CF-BD3C-008029E89281} Instance=1
*** Log Manager 0: Closed on: 8-11-2004 [20:27:18]
I just reinstalled my system, cause this was a total F*CK UP, It runs perfectly now,
Have a VIA based motherboard, an Audigy souncard and a ATI AIW 9800. The worst combination but when setup properly it just works.
I use the KX project drivers now as I do not do gaming and I think the music capabilities of these sound drivers are far more better then the original heavy SB onez
These might be helpfull for others having problems:
http://www.sanx.org/tipShow.asp?articleRef=218 (showing all former installed hardware), These remain in the registry but dont show in the hardware list. Whit the suggested key, you can see them again and safely remove them
http://www.free-codecs.com/DirectShow_Filter_Manager_download.htm this will give you insight in the registry hives of all your direcx filters and devices, perfectly for repairing faulty links and combinations
I have atimmc.exe error after installing pinnacle studio 9. This is my log. Can anyone tell me where is the problem and how to correct it? Thanks...
*** Log Manager 0: Opened on: 13/11/2004 [20:45:40]
[20:45:40] [TenFtUI] Startup: Succeeded to SetRendererMode OSI Controller
[20:45:40] ResMngr::GetObject CoCreate Error: ClassNotReg CLSID: {CA0974B8-2353-41AC-9562-7FD6BA6B27A3}
[20:45:40] [MsgBox] Startup: Failed to CoCreateInstance for IID_IRemoteWonderInfo interface
[20:45:40] [TenFtUI] LoadApplet: Failed to startup applet {F80F96F3-F597-4BBE-9C39-A6F742A06057}
[20:45:41] ResMngr::Found Feature: Name=TV Cmd=TV+ GUID={AD74FB65-D55F-11D2-A41B-00104BC83279} #of Extensions= 0
[20:45:41] ResMngr::Found Feature: Name=Player Cmd=MFPlay GUID={5C4A58AB-CA7E-11CF-BD3C-008029E89281} #of Extensions=16
[20:45:41] ResMngr::Found Feature: Name=VCD Cmd=DSVCD GUID={5C4A58AA-CA7E-11CF-BD3C-008029E89281} #of Extensions= 0
[20:45:41] ResMngr::Found Feature: Name=CD Cmd=CD GUID={5C4A58A4-CA7E-11CF-BD3C-008029E89281} #of Extensions= 1
[20:45:41] ResMngr::Command Line=/TV+ UIO Guid=
[20:45:41] ResMngr::Loading Feature ID: {AD74FB65-D55F-11D2-A41B-00104BC83279}
[20:45:41] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[20:45:41] TVUIO::PreStartUp - Optional ConO DV failed to load
[20:45:41] TuneCon::PreStartUp: Gemstar DataEngine is not registered
[20:45:41] TVUIO::StartUp: Display ConO - Multimonitor mode on via registry
[20:45:41] TVUIO::StartUp: Display ConO - Invoking Startup...
[20:45:41] Display::Could Not Localize RegPath for \Title
[20:45:41] CTvDisp::SetupDriverObject: Using DirectShow Drivers
[20:45:42] CDrvDisp:SelectDecoder: Name=ATI Rage Theater Video Capture Index=1
[20:45:42] CDrvDisp:Setup: Starting with 2 Crossbars for Audio & Video
[20:45:43] CDrvDisp:Setup: Preview Out is not available on Capture Filter
[20:45:43] CDrvDisp:Setup: Starting up using Format Converter as Capture Tee
[20:45:43] CDrvDisp:SetDefDispMode: Selecting Video Capture Display Mode: 0
[20:45:43] CDrvDisp:SetBestCapture: Setting Capture Pin: 720x240 @59.94fps (165722112bps)
[20:45:43] CDrvDisp:SetVBIFormat: SetFormat: 1 on VBI pin
[20:45:43] CDrvDisp:SetVBIFormat: VBI pin NOT connected
[20:45:43] CDrvDisp:SetVBIFormat: MediaType on VBI Pin: Standard Succesfully set to: 1
[20:45:43] CDrvDisp:SetFmtConvert: AIW
[20:45:43] CDrvDisp:SetFmtConvert: Video Delay set to 200
[20:45:43] CDrvDisp:Setup_LiveStdPerf: Rendering Live Video via VideoPort
[20:45:45] CDisplay::IsAlphBlendingSupported: 1
[20:45:45] TVUIO::StartUp InitDisplay Completed Succesfully
[20:45:45] TVUIO::StartUp: Video ConO - Invoking Startup...
[20:45:45] CPrivateVideo: StartUp: Using DirectShow Drivers
[20:45:45] TVUIO::StartUp: Teletext ConO - Invoking Startup...
[20:45:45] CDrvTeletext_DS:GetVBITee: Using Sink-to-Sink Tee Inserted by DisplayConO
[20:45:45] CTeletext_DS:ConnectRenderer: Succeed to connect ATI TT2CC with ATI Teletext Renderer
[20:45:45] CTeletext_DS:Setup: Failed to connect VBI Tee to Teletext Decoder
[20:45:45] CTText:: Teletext ConO Found the font file atittext.fon
[20:45:45] CDrvVideo::Before validate, GetGamma (1234100)
[20:45:46] TVUIO::StartUp: Closed Captioning ConO - Invoking Startup...
[20:45:46] CDSCCaption:ConnectRenderer: Connected ATI TT2CC with ATI CC Renderer
[20:45:46] CDSCCaption:ConnectTee: Decoder not in graph, no need to connect to Tee
[20:45:46] CCap:Caption: Attempting to Load & Initialize Closed Captioning Drivers...
[20:45:46] CCap:Caption:Captioning Source has been STOPPED
[20:45:46] TVUIO::StartUp: Sound ConO - Invoking Startup...
[20:45:46] CTVSound: StartUp: Using DirectShow Drivers
[20:45:46] CSoundControl_DS:Setup: start OK
[20:45:46] NumAudioDrivers:found (int) 1 drivers
[20:45:46] CDrvAAudio:RewireAudioCapture: Audio Crossbar IS used for Audio capture
[20:45:46] TVUIO::StartUp: Tuner ConO - Invoking Startup...
[20:45:46] CTunerControl_DS:SetTunerMode: AMTUNER_MODE_TV
[20:45:47] CoCreate IAtiLCS tuner
[20:45:47] Invoke IAtiLCS::Connect() with WDM TV tuner filter
[20:45:47] TuneCon::SetCable:: is not available in supported country list
[20:45:47] TuneCon:CPrivate::StartUp: Current Cable Country Code: 0
[20:45:47] TuneCon:CPrivate::EPGAppInstalled - GuidePlus+ not installed!
[20:45:47] TuneCon::ATItvtvInstalled() - Searching for ATITVTV.EXE in: C:\Programmi\ATI Multimedia\tv\atitvtv.exe...
[20:45:47] TuneCon::ATItvtvInstalled() --> Found!
[20:45:47] TuneCon::StartUp: Loaded new tuner page: 11745552
[20:45:47] TVUIO::StartUp: Time Shifting ConO - Invoking Startup...
[20:45:47] CPrivateTShift: StartUp: Using DirectShow Drivers
Interesting how SO many (dare I say ALL?) people have this error:
In fact if you do a search on the GUID you get nothing but references (log dumps like the ones above) from people who have this error. What exactly is that class supposed to be? Hmmm...
On the bright side there do not seem to be toooo many references to the error:
CPrivatePip: Startup: Failed to Verify TV Wonder Vendor
Perhaps it's just a new problem that hasn't popped up a lot yet. What's interesting is that I don't have a TV Wonder I've got an AIW, so maybe that's why MMC can't verify the vendor. Duh.
I just get an error - "Fatal Error AtiServ Logmanager Failed to startup!" I've set up the registry key exactly and even reinstalled MMC. Using a registry monitor seems to show MMC finding everything it needs!
Any thoughts? I'm using MMC 7.6, Catalyst 4.10, DirectX 9c, Windows ME with a Sapphire 9200 VIVO.
Cheers,
PJay
